Dash digital display not working on 2012 RS Vector
Rons
Ennismore
Canada
2012 RS Vector
I just was able to fix one recently - what's the symptom - dead?
Yes dead nothing on screen but machine runs ok.
Did you recently jump start it?
Check your tail lights while the motor is running. If they are out, its just a fuse.
Should be the 10 amp fuse in the fuse box. Have a look. Should be a spare there also.
I found a 3amp fuse blown signal system fuse replaced but still display is blank
There was a blown zener diode to the right of where the wire harness plugs in. There's actually two of these diodes on the pcb. I tried like heck to figure out the color code but ended up removing the good diode and took it in to work and hooked it up to a curve tracer and figured out the breakdown voltage to be about 14V. With a DVM the bad diode read about the same in both directions.
Well - did you open it up and take a look around with a DVM yet?
I didn't take a pic when I had it all apart - but if want to take a pic of the circuit board and post it here I'll be happy to circle where to check and repost it.
