Rons
Dash digital display not working on 2012 RS Vector
pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
I just was able to fix one recently - what's the symptom - dead?
Rons
Yes dead nothing on screen but machine runs ok.
pdiddy
- Oct 12, 2004
- Southern Maine
Did you recently jump start it?
Vectornut
Check your tail lights while the motor is running. If they are out, its just a fuse.
Rons
NoDid you recently jump start it?
Rons
Thanks, I will check. What fuse will it be?Check your tail lights while the motor is running. If they are out, its just a fuse.
Vectornut
Should be the 10 amp fuse in the fuse box. Have a look. Should be a spare there also.
Rons
I found a 3amp fuse blown signal system fuse replaced but still display is blank
Rons
How did you fix the one you had?I just was able to fix one recently - what's the symptom - dead?
pdiddy
- Oct 12, 2004
- Southern Maine
There was a blown zener diode to the right of where the wire harness plugs in. There's actually two of these diodes on the pcb. I tried like heck to figure out the color code but ended up removing the good diode and took it in to work and hooked it up to a curve tracer and figured out the breakdown voltage to be about 14V. With a DVM the bad diode read about the same in both directions.
pdiddy
- Oct 12, 2004
- Southern Maine
Well - did you open it up and take a look around with a DVM yet?
Rons
Sorry what is a DVM and what does the diode look like. Do you have a picture and how do you check diode?Well - did you open it up and take a look around with a DVM yet?
DVM= Digital Volt Meter
Diode= https://www.google.ca/search?q=zene...pXUAhVn34MKHTkdCvQQ_AUICigB&biw=1920&bih=1050
pdiddy
- Oct 12, 2004
- Southern Maine
I didn't take a pic when I had it all apart - but if want to take a pic of the circuit board and post it here I'll be happy to circle where to check and repost it.
