newtron
- Jan 2, 2010
- 2020 900 ACE Turbo, 2019 SRX, 2018 850 X
I searched the forum , but never got a real answer.
I put a stud through my heat exchanger and ran it with the yellow light on for a little ways. Fixed the exchanger, but it now only idles on 3 cylinders and runs rough until you get up to cruising speed.
Did i cook a cylinder or is there something else?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Melt a sensor
newtron
- Jan 2, 2010
what kind of sensor? sounds better than head gasket or engine
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Check if all plugs are firing, if they are do a compression test.
