ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
375hp at 24 psi Sunoco Supreme 115 race fuel
355 hp at 22 psi Sunoco Supreme 115 racefuel
312 Hp at 18 psi Pump fuel
Dam Tarzan you be “King of the Jungle” with that MoFo!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Guess...... gt2871?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
TD05 I bet
Nice intercooler.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yea it’s huge!Nice intercooler.
Jakeshupe79
- Oct 11, 2017
- Grace
- 2017 yamaha sidewinder evo tuning
Very Nice!!!!!Got my Sidewinder done in McxPress dyno yesterday.
All the works with the motor work and turbokitt Ecu mapping and Efi mapping sings lovely togeher
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
I use a BorgWarner Efr Turbo.What turbo?
NYTurbo
Wow that's a pile of hardware. What's the price tag on this kit ?
Wingwong
- Mar 20, 2018
I’m guessing north of 10 000$
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Well the motor is done right with rods,pistions,WOW, please tell us more about the kit shown.
Any more room for additional HP gains (changes to timing, boost, etc?)
What will you run for clutches and clutching?
Kibblewithe racing spring kit CNC’d Titanium Retainers and Cr-Si dual springs provide valvetrain control at high RPM with high performance camshaft compatibly.
Head cams with higher lift.
Manuel cam adjuster.
11mm Arp 2000 studs
Mcxpress header
Mcxpress stage3 intercooler
Mcxpress Efi with 3 injectors in the intercooler
M&M Racing Ecu flash with raised rpm limiter and adjusted timing and fuel.
BorgWarner EFR 6258 turbo
Apex oiltank
Fuel catch tank
Bigger fuel pump in tank + Boch fuel pump from catch tank.
Mikuni (Mcx) fuel regulator.
Apex Primary clutch and Viper sekundary clutch
Thunder products 911 cover and Heavy Hitters
405HP at 26.8psi
375hp at 23.7 psi
and 312 hp on pump fuel.
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Stock Sidewinder in McxPress dyno 192hp
Wingwong
- Mar 20, 2018
11mm Arp 2000 studs
Mcxpress header
Apex oiltank
Fuel catch tank
WThunder products 911 cover and Heavy Hitters
405HP at 26.8psi
375hp at 23.7 psi
Not sure if you have named this machine yet, but FrankenWinder is a good fit, Great work for sure
Looking forward to race results
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700
- Niles, Oh
Awesome build!
Any bets on how long the clutch and belt will last on that sled???
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Beautiful!!!
My avatar is a Borg Warner! They are the best turbos IMO. Super reliable, fast spool, all in one BOV and wastegate. I’m doing my girlfriends R1 with an EFR! Waiting for the motor to get back from the machine shop now.
Awsome that someone is using this turbo and not the standard Mitsubishi.
Will the block and crank be ok, or is there other modifications to those as well?
Thanks For this, CM
Thanks For this, CM
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Yes the BorgWarner EFR turbos have very fast spool up and deliver nice hp.Beautiful!!!
Thanks For this, CM
The crank and block are very strong stock on 998cc so no work there
And they can take lots og hp if all is done right
R1 with a BorgWarner sounds beutiful,will make the back tire rip the asphalt
