- Apr 14, 2003
- Hessel, Michigan
Kinger, I have a bottle blanket, and a couple bottle heaters I will not be using. Mostly new condition, let me know if you need something.
I can do that for ya, and you want the LED surface mount switch I use? You have the rubber push button, correct?
kinger
Yes I have the rubber push button for running teh nitrous but I have two switches hid in the foot well. One for the bottle blanket and one for the nitrous activation to make the pushbutton 'hot' so to speak. I would like a red and green LED to illuminate on teh dash when either of them are on. Your just talking LED switches though uh? Are they waterproof, I could change the switches in the foot well and get the same result. Thanks!
culvert
if your refering to my ? NOS. Then yes I would like a led switch(blue) and a mount bracket. Same push botton thats in the pics.
Thanks, Culvert
Thanks, Culvert
- Apr 14, 2003
- Hessel, Michigan
culvert said:if your refering to my ? NOS. Then yes I would like a led switch(blue) and a mount bracket. Same push botton thats in the pics.
Thanks, Culvert
I will check at our store, as I know they have red and green, but blue are hard to come by.
- Apr 14, 2003
- Hessel, Michigan
kinger said:Yes I have the rubber push button for running teh nitrous but I have two switches hid in the foot well. One for the bottle blanket and one for the nitrous activation to make the pushbutton 'hot' so to speak. I would like a red and green LED to illuminate on teh dash when either of them are on. Your just talking LED switches though uh? Are they waterproof, I could change the switches in the foot well and get the same result. Thanks!
Our local store here has red, green, and yellow LED lights that you can mount on your dash. Just connects between power supply to solonoid, heater, etc. to let you know that it has power going to it. The switches are not rubber coated, and may get water into them, but I haven't had any problems...KNOCK ON WOOD.
ApexRtxGuy
how much could i expect to spend on a nitrous system on an 07' apex rtx with stock air box? thanks in advance
stoutner
$700 - $1300 depending on which kit you buy. Also figure another $300 - $500 for extra bottles, hoses, scale etc.
remember, if you are spraying a 50 hp shot of nitrous, a 3 lb bottle only give you about 50 seconds of nitrous. You will need extra bottles full and ready to go if you plan on using it a lot.
Once you get it...you'll use it
- Apr 14, 2003
- Hessel, Michigan
ApexRtxGuy said:how much could i expect to spend on a nitrous system on an 07' apex rtx with stock air box? thanks in advance
Sent you a pm
- Apr 14, 2003
- Hessel, Michigan
Culvert - did you get the bracket and switch o.k.?
culvert
Nothing yet Terry. I'll let you know when they get here.
- Apr 14, 2003
- Hessel, Michigan
Sent it out last week, holy cow! Slow travel.....
maxdlx
I think Culvert mailperson is lazy. Everything sent to hime gets there slow. LOL Maxdlx
nitro express
crazy canuck said:Are there any jetting changes required? What do you run your rpm's at when off the bottle...what does it go up to when on it?
I ran his kit on my BB viper for 3 years just clutch for normal running...the extra 3-400 rpm with the added fuel and nos pull real hard I never changed jetting as jis kit adds fuel a hair before the nos shows up.............02
