Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
Pretty sure I know the answer but just want to confirm. I'm extending my Apex to 144. If I go to a 1.75 Back Country, will I have to remove my tunnel Protectors ? With a 1.5 cross over I can leave them in...correct?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I had to.
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
Wnen I installed a 1.5" lug track on one of my Apex based sleds the tunnel protectors needed to be removed for proper clearance.
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
Nice to know. I thought the 1.5 would clear. If I have to remove the protectors for a 1.5 then the 1.75 will be going on anyway
yamahahaha
guy i know has a 1.75 on his i think, its a camoplast of some kind
YamerHammer
I have put 3 back country tracks on attaks and every owner said the samething as I, this is the way the sled should have performed out of the box. The back country turn this sled in a different animal. On and off trail.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
YamerHammer said:I have put 3 back country tracks on attaks and every owner said the samething as I, this is the way the sled should have performed out of the box. The back country turn this sled in a different animal. On and off trail.
Big time
skey01
So do the tunnel protectors have to come out ??? I am assuming yes but you know what they say about assuming!! LOL Being new to Yamahas I really don't know ????YamerHammer said:I have put 3 back country tracks on attaks and every owner said the samething as I, this is the way the sled should have performed out of the box. The back country turn this sled in a different animal. On and off trail.
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
Sounds like they will have to for the 1.75. Still looking for clarification on 1.5
skey01
Where are you in NFLD, I hunt there alot !! I love the people, have made lots of friends there!Phazernut said:Sounds like they will have to for the 1.75. Still looking for clarification on 1.5
YamerHammer
Yes the protectors come out and skey01 it would be so close. All you have to do is flip the sled on it's side and measure.
Lester
with an 1 1/2 or bigger lug track they must be removed,been there done that
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
skey01 said:Where are you in NFLD, I hunt there alot !! I love the people, have made lots of friends there!Phazernut said:Sounds like they will have to for the 1.75. Still looking for clarification on 1.5
Living on the east coast right now outside of St John's. Grew up in central NFLD in Buchans.
grader
you could drop the drivers down to 8 tooth and run the 1.75 with the protectors in. this will be costly with the new drivers and possible gear changes. you only need the protectors for studs anyway, and wont be studding a 1.75.
schmeg
I pulled mine. Its that or you need to trim the paddles that are in line with the windows.
