yamaracer18
- Aug 14, 2008
Should the track droop In the middle or is it to loose?
yox185
If you tighten it so it doesn't droop you will get about 10 miles out of your slides. Mine droops about 1.5" with no ratcheting.
Dimebag
If your sled has extros you can run the track pretty loose..
AttakDog
The XTX wont ratchet, run it loose!
linemech31
"The XTX wont ratchet, run it loose!"
Yes it will. Dont run it to spec tight, some droop is ok.
Bahr05
My XTX ratchets like a Bass-Turd if the track is loose. What I did with mine is align the track so it runs straight, then take it out and ride it. Get a good traction area, and pin it. If it ratchets, I tighten the nuts a 1/2 turn and try it again. I do this over and over until it quits. This way the track is as loose as it can be.
You can also do this backwards too. If it doesn't ratchet, back the nuts off a 1/2 turn until it does, then tighten again. There is an 1" or so of droop in my track when I'm done. Just my $.02 worth.
bitchnblue09
track
So i guess what you are saying is if the track is tight the more its gonna wear the hi-fax down?? the looser the track the longer your hifax will last? Does this sound right???... Think the manual says, 0.98 - 1.19 at 22 lbf i believe, or close to that, so i guess you guys are sayn without the 22 lbf theres 1 in. of sag... is this correct? Is the sag there when you lift the sled up in the rear?? Thanks, just want to clear this up...
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
i wouldnt use the spec just trial and error, spec i find is way too tight
