Kevin
decided to open up chaincase to make sure everything is ok
To my surprise the washer that goes on end of shaft to protect case is missing
Well not missing but pieces everywhere
Is this a special washer or can I just use a stainless washer ?
Pstn head
Id say it's a pretty specific washer (thrust washer) but don't know for sure.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
How many miles? Pics of what you speak of? How is your chain adjustment? You noticing a lot of stretch?
Kevin
8500 Kms
Likely from just splitting the cases last year to drain fluid
No other damage
No other damage
JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
8500 Kms
No other damage
When you did fluid change, usually the washer gets "stuck" on thr case itself did you take the washer off tgr case and put it on the shaft? If not it could have just sat in there.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
This?decided to open up chaincase to make sure everything is ok
https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-rockerdan.149801/page-20#post-1406950
Mototown
It needs to be same thickness & centre hole needs to be close to sizedecided to open up chaincase to make sure everything is ok
Kevin
Just cracked the case last year for fluid changeWhen you did fluid change, usually the washer gets "stuck" on thr case itself did you take the washer off tgr case and put it on the shaft? If not it could have just sat in there.
So rode all year like that
