Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
Curious as to what the optimal RPM is on a sidewinder? Seems there's lots of variation in max RPMs here. There must be some actual noted power band. Hoping tuners can chime in on this with where they make peak performance.
Yaahoo
- Nov 23, 2018
- Belmont NH 03220
- 2018 Yamaha Sidewinder LTX 137
Wonder this the same? Just adding turbo dynamics max spool 17 and wonder what target top rpm is? Up graded bov,dalton weights,super quit exhaust and cai. Itching to ride this rocket but don’t want to over rev!!
fourload
Stock, Td and Hurricane all seem to run them at 8800-9000.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Above stated 8800-9000
Yaahoo
- Nov 23, 2018
- Belmont NH 03220
Thanks guy!! Old triple guy. Always ran and loved triples but these four stroke turbos are new to me! Feels like a Mad Max machine!!! Love it!
Mototown
8800-9000 , check your intake tube clamps before and after couple hundred miles
Yaahoo
- Nov 23, 2018
- Belmont NH 03220
10-4 thanks. Is that a on going thing?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
8750 stock peak rpm,boosted sleds may be a tad higher.
WinterWolf
- Mar 25, 2017
- Connecticut
Just had mine Dyno’d...Hurricane SM Flash Bundle installed, and the peak power for all 3 of my Tunes was 8700 RPM; Once past that the power drops off.
Same with stock tune..8700 was where it made the most power stock.
Mototown
If you have a boost gauge it's easy to track , but mine was running in the 16 psig range for the first 170-200 mile range , then it dropped off into the 15 range . Went through all connections on the boosted side , the one coming off the turbo was loose . Pressures back into the 16.5 to 16.9. Your boost pressure is more important than whether your sled rpm is running 8700 or if it's 8900 .10-4 thanks. Is that a on going thing?
Yaahoo
- Nov 23, 2018
- Belmont NH 03220
Sounds like another thing to get! Any surgestions on a good one?
Mototown
If you flash it should be on your dash, it changes over your hr meter
Yaahoo
- Nov 23, 2018
- Belmont NH 03220
They should give you some info on these flashes. I spent over $1400 on a flash and extras and not one piece of info on it. Not even a sticker! Lol. Thanks for the info I have yet to try this set up. Trails open here December 15th can’t wait
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
what tune was running 16.5 to 16.9If you have a boost gauge it's easy to track , but mine was running in the 16 psig range for the first 170-200 mile range , then it dropped off into the 15 range . Went through all connections on the boosted side , the one coming off the turbo was loose . Pressures back into the 16.5 to 16.9. Your boost pressure is more important than whether your sled rpm is running 8700 or if it's 8900 .
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Also if you have a TS BOV check your banjo nut on bottom,they have had a problem with a couple,remove bot and install red locker on threds.If you have a boost gauge it's easy to track , but mine was running in the 16 psig range for the first 170-200 mile range , then it dropped off into the 15 range . Went through all connections on the boosted side , the one coming off the turbo was loose . Pressures back into the 16.5 to 16.9. Your boost pressure is more important than whether your sled rpm is running 8700 or if it's 8900 .
- 33K
- 40K
