stgdz
- Mar 27, 2021
- Buffalo MN
What years and models came with the qs3r?
2017-2018 ltz se and the zr 9000rr. Did the 2019's come with them or did they switch to iqs?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
2017 & 2018 LTX-LE for Yamaha models were Kashima coated QS3R Fox shocks. Also the Cat 9000RR, not sure of the years on the Cat but I thought it was one year only on them possibly 2017 only.
Not sure if the longer tracked LE's possibly came with them too?
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I think the new 22 ltx le comes with them again.
KnappAttack
- Feb 19, 2004
- Welch MN
Thats awesome, Best shocks out there. I know they did away with them for a while there.
Erskin
- Feb 6, 2021
- Maine
- 2021 Thundercat
265 maxspool TD SM
- Bangor
My brother's 19 9000rr has the qs3r on it
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Yes but I believe the cats didn’t put it on all 4. Think the center shock is a regular fox.My brother's 19 9000rr has the qs3r on it
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Correct. The RR and X-RC got the regular QS-3 1.5 kashima coated shock on the front skid arm. The RR had a slightly softer tender spring rate 140lb RR---170lb X-RC.Yes but I believe the cats didn’t put it on all 4. Think the center shock is a regular fox.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
So the ole LE's with all four kashima r shocks is pretty darn awesome compared to a watered down cat rr then.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
The Cat RR has all four kashimas. Plus upgraded cross shaft, rotor etc that all the sidewinder guys want. Its too bad last year for the 9000RR was 2019. It was the best yamacat out there!So the ole LE's with all four kashima r shocks is pretty darn awesome compared to a watered down cat rr then.
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Thank you for the clarification i'm definitely not a cat guru
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
Yep. Like KnappAttack mentioned the Kashima coated QS3R shocks are pretty hard to beat.
I've got them on this '18 LTX-LE (with SRX dual rate front springs) and you can tell a difference. They just don't seem to fade out when ridden hard.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Sweet looking sled!
SideHogger
- Apr 16, 2016
- upstate ny
We didn’t get good cross shaft but did get the good rotor.The Cat RR has all four kashimas. Plus upgraded cross shaft, rotor etc that all the sidewinder guys want. Its too bad last year for the 9000RR was 2019. It was the best yamacat out there!
Mototown
After having a 21 srx with the fox iQ electric shocks and running the 22 LE with Qs3R shocks . I will be ordering the srx IQ suspension if I have the choice. The front shocks on the srx work better … might be because of the dual rate spring s on the front of the srx . Then add the adjustment on the fly just plain works …. After you figure out to control it while riding down the trail, I used it all the time & you actually feel the difference.
