Keith Schmitz
Anybody use these on other sleds? From racewerks, 5 different settings, supposed to help with transfer.
Byam
Very good and durable product.
Oem 1,2,3.
Racewrex rapid block compare to oem would be. 0,1,2,3,4,5.
Oem 1,2,3.
krm
- Apr 22, 2016
- ny
had them o my sw .just took them off to run the stk.shaft with no blocks .let me know if you want them .
Keith Schmitz
Still not enough transfer? I have the RTX SE. I was debating taking the blocks out too.had them o my sw .just took them off to run the stk.shaft with no blocks .let me know if you want them .
justin1620
- Feb 3, 2014
- Rainy Lake, Ontario
- 2018 Sidewinder LTX DX
2017 Sidewinder LTX SE
1999 SRX 700
1998 SRX 700
2005 Arctic Cat F7
- www.rustymyers.com
I tried that but it looked I was contacting the shaft with blocks removed......is their clearance and no contact if you removed the blocks but left the shaft? I have an LTX SE 137had them o my sw .just took them off to run the stk.shaft with no blocks .let me know if you want them .
Shagnos
That's what I did. Still needs a bit more transfer....is their clearance and no contact if you removed the blocks but left the shaft? I have an LTX SE 137
krm
- Apr 22, 2016
- ny
It looks like we could move the shaft back another 1/2" or so also ,or move the bottom of the rear sissor forward .
**sj**
you will hit against the bar....you can put something on the bar to prevent the suspension from slamming into it...but...heres fuel for thought...when you want to race you want the most transfer...but if you are going corner to corner...you want the opposite..well at least most riders would...you lose that ability with the block out or no racewerx block...
also...just a guess...but with the bar and no blocks...I think the racewerx block on max transfer is more transfer comparatively?
of course then with it, and a turn of the wrist you can be corner burning in seconds
Keith Schmitz
I only have 73 miles on my sled, (currently in Mexico, and Merry Christmas to all the fellow TY'ers), but there seems to be a NOTICEABLE difference with the racewerx block...that's just my opinion!
allyammies
And your on TY I would of had too many Coronas.Thats dedication.I only have 73 miles on my sled, (currently in Mexico, and Merry Christmas to all the fellow TY'ers), but there seems to be a NOTICEABLE difference with the racewerx block...that's just my opinion!
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Today I put my transfer bar and blocks back in looking for more speed. What a joke. I took my Rtx for a rip and I felt like I had no studs. Zero ski lift and track just spins. Might as well ride a 340 cc. Going to pull the transfer bar back out and hang on!
RAMSOMAIR
So run with no transfer bar whatsoever and no risk in damaging anything??
bleedyamaha
- Sep 28, 2013
- Northern Iowa
I have 2500 miles at least with no transfer bar on my Rtx le. I do have some studs pull through from trying plastics backers.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I'm going back & forth on this one.Today I put my transfer bar and blocks back in looking for more speed. What a joke. I took my Rtx for a rip and I felt like I had no studs. Zero ski lift and track just spins. Might as well ride a 340 cc. Going to pull the transfer bar back out and hang on!
Blocks out & I can't keep the skis down (280 tune)
Blocks in, and its fighting to bite.
Added 48 more studs to see how it all works out.
Technically, you'd want the blocks in, then fight for traction.
What do I know?!?!
Adjustable blocks will be one of my next accessories to purchase, to keep me pointed where I need to go when the power is being put down.
Which is most of the time.
