ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Got hold of my guy here, so gonna take sheave in for pocket machining.
I have a good idea how much I want to take out, but want to get consensus from guys here that already have done theirs.
So how much are you guys removing on the sheave pocket?
thnx
Dan
thnx
Dan
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
thnx
Dan
.070
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Thanks Shag for quick response, on my way over to his shop soon!
Dan
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Im thinking I want to massage the tang hole after machining, to create a nice seat so spring sits flat.
Dan
Dan
shagman
Vendor
- Feb 18, 2014
Dan
Yep dremel.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
thank bud! Will do.Yep dremel.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Sheave dropped off at machinist......
.070 coming off(1.77mm in metric terms)
Dan
Dan
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
I'm on the fence permanently changing the secondary so have it shimmed for now. What happens if Dalton or TPI come out with a better spring with more force and one less coil? Will the deepend pocket then be a problem?Sheave dropped off at machinist......
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
cant see it making much difference, its only 70 thou....(1.7mm)I'm on the fence permanently changing the secondary so have it shimmed for now. What happens if Dalton or TPI come out with a better spring with more force and one less coil? Will the deepend pocket then be a problem?
I have setup my doos with compression springs with and without the delrin type washers(more then 2mm in total) on each end of the compression springs, and they dont change the overal setup much at all.
On a torsional spring the side pressure has even less effect then a compression spring, so I dont see it making much diff. And now I can wrap to 6/1 for a snappier bottom/midrange.
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 nytro rtx, 2005 RS Vector MTN turbo
Hey guys just wondering how much travel do you have left on the sheave shaft where the helix bushing slides on, on mine it looks like I only have a half mm left as it looks like machining my pocket wouldn't gain me anything. I'm thinking I may need to do gears rather? Silly thought what do you guys think?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
0.75 on mind +Gforce 41-37 helix
0
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
Please keep us posted on how your new G-Force set up works out.
Looks mint.
Looks mint.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
The quick torsion adjust is VERY nice to work whit
. You can change the "leg angle" on the fly whitout removing the cam........
41-37 not sure yet for "stock sled" stock weight was 72,6gr 72,5 and 72.3 gr........
rpm was to low8200-8300 on long pull in realy soft condition...
OeM have 4,5gr rivet in each 3 hole.
I have replace the first one for the 2,44gr rivet. The 3 are now 70,5 gr rpm Torsion at 65degree
187gps 193 speedo 8600-8700 rpm
did not test this in every condition work in progress
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
very nice! I was hoping to see someone try the new Gforce adjustable HELIX, cool cool design for guys who like to test!
Can you tell me the range of adjustability with that? is there a min and max ramp angle? Can you go to a reverse angle(Shallower then steeper)
Do you have to buy more "ramps" for each angle you desire?
Please let us know how it works!
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I read somewhere that Dalton said machining the helix wasn't necessary.
- 6K
- 6K
