scott bardwell
- Jan 5, 2015
- Ontario, Canada
- 2017 Yamaha Sidewinder LTX DX
FYI it turned out being a exposed/worn wire higher up in the headlight harness that caused the short. Thanks for everyones help
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
Thanks for the update! Was following.
It still should have popped the fuse before burning up the connectors at headlight. Either way I assume you had to replace the connectors and fix the short in wiring?
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
That fuse should have blown. The worn insulation may have been from the wire heating up as a result the insulation can soften and would appear to be damaged or "worn". If the insulation were worn it should not have any affect on the socket however the failing socket would affect the wire. Either way the fuse should have blown. I would keep looking.
Right. OP had two issues. The poor headlight connection and the bad insulation. It could not have actually shorted or fuse would have blown. Scary.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I know you said it was the stock fuse but I'd still check to make should they actually put the 20amp in there! I don't take anything for granted on this sled!
