This is all the info I could find on it. I have not heard of anyone seeing the code or whether or not the code appears if the Protections the Knock Sensor provides are employed. Those running stock can and a tune should have seen the knock sensor employed if run for any amount of time with a tune based on 1100 cat. Anyone see anything or feel anything?
PowderFalcon
Pinnin' it!
Good info cannondale... would be interested to know if anyone has experienced that code yet. i certainly have not.
also not sure why/how a flash from any of the players out there would disable this feature seeing how vital it is to the engine.
Nobody has said that anyone disabled it. What was said was that it doesn't work from the factory. I cannot fathom that. Cat 1100 it worked and I know my Phazer which has one it has engaged but it took some real junk gas. If no one has seen it yet then I have no doubt its not working. Like I said on cat 1100 with tune and stock can any long run knock sensor would be employed. There are some running with stock can and tune. If that sensor isn't working they would never know they could be damaging the engine. Bad gas etc. same thing.Good info cannondale... would be interested to know if anyone has experienced that code yet. i certainly have not.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
I've had mine pull back on long pull up gogebic went from 8900 rpm to 8400 but intake temps were also 120+ not sure if it was knock or high intake temps but my cousins NA nytro passed me it wasn't cool I always run 91 now I have cat grille and run amsoil octane boost and haven't had that happen since.
HURRICANE
The knock software doesn't appear to exist in the 2017 Ecu
Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
There is a knock sensor yes. There is code for it. But the Ecu does not do anything with the frequency readings. We actually have a working knock light based on knock retard. But it won't light up if the Ecu does not detect the frequency and analyse it, it will not retard timing. We are working on activating the function. Will be ready before next season imo.
The good thing is that motor does not knock easily. 265hp powertrail ran on all fuels and all kinds of conditions. But I'm careful with the higher power ones like max 17
www.turbodynamics.ca
HURRICANE
We induced a forced knock on the engine during testing of the knock light. As I ran the engine under severe knock conditions the sensor displayed no change in value ,reading from the ecu
What about from the sensor? Is it possible the factory found it unreliable and just disabled it at the ECU? That could be changed easily if it can be made reliable.We induced a forced knock on the engine during testing of the knock light. As I ran the engine under severe knock conditions the sensor displayed no change in value ,reading from the ecu
HURRICANE
I suspect that its like the first year of the srx. The knock sensor was present but didn't work till the following year when Yamaha finished the software in the ecu.we are ready to implement the knock light as soon as they release the ecu that will support it.
PowderFalcon
Pinnin' it!
Gives yamaha a good excuse to get them all back in for an ECU update for the knock sensor with the added bonus of placing a tracer in there for boost pressure to tell who is running aftermarket flashes when/if they grenade! How brilliant of them!
The tracers are there already. Whether they use them is up to them.Gives yamaha a good excuse to get them all back in for an ECU update for the knock sensor with the added bonus of placing a tracer in there for boost pressure to tell who is running aftermarket flashes when/if they grenade! How brilliant of them!
PowderFalcon
Pinnin' it!
I wondered.... that's been a long debate as well. Some say they are not traceable yet, some say they are. hmmmm.
I will look again but pretty sure max boost is readable.I wondered.... that's been a long debate as well. Some say they are not traceable yet, some say they are. hmmmm.
PowderFalcon
Pinnin' it!
Thanks, really got me curious now!
lilrez
Who's shaking now...Lol.
- 11K
