done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
I have one on my '14 gsx se, set it on the new stx 137 dx, fit perfectly. Ordered the bracket from UNP, be here tomorrow to install. Love my big trunk for my lunch box and street clothes when riding to work. But I don't take it off to carry around either.Will not fit the 137 Winders due its shape and the Winder 137 is 2.5'' shorter than a 137 Viper. I would not recommend anyways.
I had one on a Doo Renegade and its was a bulky pain in the a$$. hard to carry no handle and heavy once loaded. I sold it a went back to 2 medium Linq bags and was much happier.
dgjr636
The new mounts from UNT that fit the 137 Sidewinders won't be available till mid-end of the month. If you have the old LMP-2 mount on order it will not fit the 137 winder without major cutting for clearance of the taillight.
From UNT
I just received word from our fabrication vendors earlier this week that expected delivery date for the new LMP-2's is 12/14 or sooner. I ecouraged them to make every effort to improve upon that date if possible, but I'm communicating to customers the 12/14 expected ship date. Lots of backorders for these!
Thanks again for the follow-up - I'll let you know when the new LMP-2's are ready.
Ken Larson
Offroadin
- Jan 17, 2015
- South of Ottawa
- 2017 Sidewinder LTX-LE,
Woody's/BOP/UNT/Sentinel guards&LED/LinQ
So, I called UNT this evening but i guess it was too late.. I will try again tomorrow and place my order for the double bracket to fit on my LTX-LE. I guess the question i now have is:
- What is the best configuration to maximize
I was intending to go with the single bracket but now that the double is out, I am going in that direction now.
- Fuel Carrying capacity
- Baggage carrying capacity
Hammer Down
- Oct 7, 2016
- Loudon, NH
- Sidewinder STX-DX 2017
Apex XTX 2012
Hi done doin I also have a STX 137 could you please let me know how this works out? Will you need to remove the tunnel bag for proper fit?I have one on my '14 gsx se, set it on the new stx 137 dx, fit perfectly. Ordered the bracket from UNP, be here tomorrow to install. Love my big trunk for my lunch box and street clothes when riding to work. But I don't take it off to carry around either.
- Dec 6, 2016
- saegertown pa
wow. you are right and my sincere apology to all for saying it would be here tomorrow. i have the new bracket ordered. i looked back through my mail and delivery must be for something else i have coming. it doesn't say what it is but it isn't from the right state. lost track of all the orders. but the trunk did fit with stock bag removed without hitting light etc...thanks for the heads up, and again my bad...The new mounts from UNT that fit the 137 Sidewinders won't be available till mid-end of the month. If you have the old LMP-2 mount on order it will not fit the 137 winder without major cutting for clearance of the taillight.
From UNT
Ken Larson
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Seems like you could use a rack like the Pro-Series plus the double rack to adapt it to fit with a little cantilever over the tailight. Of course that would get pricey.
woodzynh
- Sep 11, 2012
- Nashua, NH
- 2015 Yamaha Viper XTX LE
I would still like to know the dimensions of the LMP bracket with gas tank so I could see if it will fit with the Yamaha shovel pack....anyone?
dgjr636
I will see if I can come up with some measurements tomorrow for you. Are you interested in the 4gal stackable fuel caddy or the 3gal non stackable. I would assume you want the single mount LMP-1 bracket.
woodzynh
- Sep 11, 2012
- Nashua, NH
Thanks!! I'd like the smallest one, sounds like 3 gal non stack , only one needed as I want to use my tunnel shovel pack and have some gas just in case [emoji106]
dgjr636
I would do the same. The 3gal tucks into the seat and fuel tank better than the 4gal do to its shape.
dgjr636
The LMP-1 bracket is 12" at its longest point and the 3 gal fuel caddy is 14'' at its longest points. The way its shaped and if mounted closest to the fuel tank it takes up about 13'' of tunnel space.
Hope this helps
woodzynh
- Sep 11, 2012
- Nashua, NH
Thanks, I measured my tunnel....would need to run the tank on the end and the shovel bag near the seat....it would be tight.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
Here is my setup I just got back from powdercoat just waiting on the correct 2.5gal gas can the holeshot bag fits perfectly and there is lots of room in the bag just have to finish mounting it! Very happy for under $200 and I kept the factory bag
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
What are the dimensions on the Yamaha shovel packThanks, I measured my tunnel....would need to run the tank on the end and the shovel bag near the seat....it would be tight.
woodzynh
- Sep 11, 2012
- Nashua, NH
I measured it this AM, think it was 18" long
