Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Belt # 5 down.
I'm at the end of my rope. Every belt is going differently. 2 have exploded ( 8dn!). 2 have snapped in half and one was caught coming apart.
What am I doing wrong? I've checked the offset. It is in spec, at the limit but in. New rollers , spring jacked to 6-1 but blew belts at 3-3 also.
I'm seriously thinking of trading for an apex. At least I can go and not worry about these damn belts.
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
That really sucks. I would be pissed too. What does the dealer say? How many miles are you getting on each?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
It's hard to say how many miles on each. The sled has 4000 on it.
Just when I think I got it figured out. Ka boom.
**sj**
have you had the dealer look into it?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Ya. Said offset was good. No helphave you had the dealer look into it?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Do you have coil bind? Is your deflection set correctly?
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
BRP Renegade mxz 800
Do you "break-in" your belts?
Sent from my SM-T705W using Tapatalk
Has your dealer been in contact with Yamaha? I would be pushing for a clutch swap right off another Winder. Both of them. Push your dealer to make the calls to get it done. Document everything.
Grimm
It's that all your dealer looked at, the offset?
What about your primary? ...could be broken spring, worn bushings & sliders. How about chaincase tension and oil level? Jackshaft and driveshaft bearings? Poor drive line efficiency creates heat in the clutches, causing a burnt belt.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I think the fix & final conclusion will be at years end after much testing. I personally talked to multiple tuners & they are working on it. There is a dealer or shop in Maine that claims to be able to have fix for this. Trying to get his name & number now & the people's names that he fixed their clutches.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
I've checked the springs. All good. The primary shows a bit of bind ( small rub on spring). Chain case is in the middle on sight glass and I've checked the tension.It's that all your dealer looked at, the offset?
Bearings look good.
I'll be hounding the dealer once the snow melts.
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
This dealer in Maine is also claiming he has Yamaha pay for it...
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Check your primary roller bushings!!!
Do it NOW while you can test it. A clutch swap takes 5 minutes. Don't forget clutches are not a normal warranty item after 90 days?I've checked the springs. All good. The primary shows a bit of bind ( small rub on spring). Chain case is in the middle on sight glass and I've checked the tension.
Bearings look good.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Ya I know. It's crazy. I'm guessing I'll be stuck out in the "cold" on this one.Do it NOW while you can test it. A clutch swap takes 5 minutes. Don't forget clutches are not a normal warranty item after 90 days?
Its a frustrating issue.
- 13K
- 33K
