Mitch Lockhart
- Dec 29, 2019
- Lakehurst, Ontario
- 2018 Yamaha SR Viper
I own a stock 2018 Sr Viper RTX 129. I recently purchased a Thunder heavy hitter clutch kit, they set the weights to my instructions running a stock 8JP belt. My replacement belt is a Ultimar XS825. I any one running with the Ultimax belt? How is the performance and how combination of weights were used?
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Tim or Terry will know what to do. If they don't chime in here, you can always contact them at Thunder Products directly.
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
Both belts will run different RPM's. The worst thing to happen would be changing some weight around on your heavy hitter fly weights. I believe the Ultimax will run lower RPM's but I'm not 100% sure, as GR8BBQ said the boys at Thunder will steer you in the right direction.
Mitch Lockhart
- Dec 29, 2019
Thanks for the quick responses I will reach out to the guys at Thunder Products for weight info
