bot
- Aug 17, 2016
- ottawa
- 2014 viper long track
Stoped for fuel yesterday put sled in reverse when i went to put back in foward her grind from actuator...got home pulled in to shop shut sled off and grinded again.. time for a new actuator??? I have vidios of it ...but it wont let me upload them..says file to large...only 10 sec vid tho
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Yep time for a new actuator.
Yours sounds like this, right?
You could re-clock the gears too like this.
Here's another to show what's going on in there.
After re-clocking my nylon gear, it lasted another season. Then stripped again.
The new update reverse actuator uses a metal gear.
Bought the updated one and no more problems.
bot
- Aug 17, 2016
- ottawa
Yuuuup ..thats what shes doing.. mines gotta be running then shut off.. but same thing... i ll order the new steel gear one.. re clockin it would be good in a pinch..but i can have a new one by thursday.. so better just put the metal gear one in... thxs frozentoes
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Out of curiousity where are you getting the metal gear from? thanksYuuuup ..thats what shes doing.. mines gotta be running then shut off.. but same thing... i ll order the new steel gear one.. re clockin it would be good in a pinch..but i can have a new one by thursday.. so better just put the metal gear one in... thxs frozentoes
bot
- Aug 17, 2016
- ottawa
Yamaha...and u can t just get gear u gotta buy hole.new actuator.. just spent 3 hrs driving ...1.5 hrs each way...and 240 bucks for the new actuator with metal gear...thank the lord i had dealer hold me one...cause they sold 2 OTHERS TODAY! ASWELL ..and i had the last one on hold ..i tore it right apaart in front of them to make sure gear was metal..
TD Max
So are they all built with a plastic gear?
bot
- Aug 17, 2016
- ottawa
Origanals were...the new ones have metal or steel gear..i d show u my old one and my new one...but for some reason my pics wont upload
bot
- Aug 17, 2016
- ottawa
Just makes sure if u goin to buy a new one...u pop the round cover off and make sure gears are metal not plastic
0llll0
GO JETS GO
- Mar 9, 2014
- Winnipeg, Manitoba
- 2014 Sr Viper LTX-SE
Does anyone have the part# for the new reverse actuator with the metal gear in it?
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Grinding can also be from the shift fork pads being broken. Eventually it wont even go into forward.
