SRX Boy
I have a LTX-LE, 137" with 144 studs up the middle. Got 250kms on it and trying to figure out the right carbide length/set up for trail riding. Have stock skis and thinking of going 6" on outside and leaving 4" that came with it on the inside. Anyone have some real life experience in this department??
Sent from my iPad using Tapatalk
Winderman69
- Dec 31, 2016
- New york
- 18' sidewinder RTX 50th anniversary
My dealer talked me into changing mine before I even took it out of the shop... Says the stock ones are useless . I put stud boy 4" on Inside and 6" on outside ... I know Yamaha says opposite but it seems to get a good bite in the corners. I like it so far but only have have 150 miles which a lot was wooded windy trails
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
The stock junk they come with will be very lucky to last to the 500 mile service.
monte1214
- Apr 20, 2005
- Durham Region, ON
- www.portperrysnowmobileclub.com
- 2017 Sidewinder LTX-SE
I probably ride some the same trails as you, and I'm running 6" and 6". Ran it on my Viper and was happy.
A little bit of push in the corners, but I don't mind that.
A quick "blip" of the throttle, or a squeeze of the brake fixes it right up.
foolery
- Sep 12, 2015
- Cambridge
- 2016 Phazer.... plus a couple of 2016 Polaris 800's
I have 6" and 6" as well. Have almost 400 miles on now and am quite happy. Lack of ski lift is my issue right now. Changed seeing on rear transfer block to #1 and shaved 2mm off to see if that's better than the #3 setting.
Teamblewbyu
- Dec 21, 2016
- Syracuse
- 2017 Sidewinder LT-X LE.
'12 800 X Etec, 11' 800 XRS Etec, 10' 600Etec, 04'800PRO XR 01' 440 Pro-X
DnD just suggested and have had good feedback on 6" shaper bars on inside and 4" regular bars on outside and it's a much better improvement over stock, going to try it out but will wind up with curve's at the end of all this....
foolery
- Sep 12, 2015
- Cambridge
6&6
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
My real life experience was throw the tuners in the garbage and pick a nice single keel skis. This chassis was built on to run single keels skis. Curve XS, CA or even stock cat skis will show a tremendous improvement in consistency.
Sent from my SM-G920W8 using Tapatalk
Sidewinder Slayer
- Dec 30, 2014
- 2007 apex rtx
2007 phazer
2017 sidewinder ltx le
Anyone have a part # for the stud boys shaper bars 6"?? My parts dept says they won't fit the tunners. Is there a special one for the tunners or just order standard ones?? They say only woody s are for the tuners.
Pstn head
Here u go, I just installed a set of shapers my self, this part # is for the tuner II but they fit the tuner III's no problem at all.Anyone have a part # for the stud boys shaper bars 6"?? My parts dept says they won't fit the tunners. Is there a special one for the tunners or just order standard ones?? They say only woody s are for the tuners.
ZachXSmith86
- May 14, 2016
- Michigan, Otisville
- 17 Sidewinder ltx se
I run dual executive 8inch, I guess I like the tail end a little loose. Point where your going and squeeze the throttle.
LabineSidewinder
- Jan 7, 2017
- st-lazare
- 2017 Yamaha Sidewinder (before Apex se 2011, Apex Gt 2006, RX-1 2003, SRX 2002, Phazer 86, enticer 300 80)
i have the stock ski alsoI have a LTX-LE, 137" with 144 studs up the middle. Got 250kms on it and trying to figure out the right carbide length/set up for trail riding. Have stock skis and thinking of going 6" on outside and leaving 4" that came with it on the inside. Anyone have some real life experience in this department??
i have put the 6 inch (square) on the inside and the original 4 inch in the outside
so far i like this formula, expecially since i have ajusted the limited strap
Sidewinder Slayer
- Dec 30, 2014
- 2007 apex rtx
2007 phazer
Are u in the states ? My dealer can't get that part # ??Here u go, I just installed a set of shapers my self, this part # is for the tuner II but they fit the tuner III's no problem at all.
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
Which direction did you go with the limiter strap? Let it out more or suck it down more?i have the stock ski also
Pstn head
I'm in Ontario Canada,buy them always at Royal Distributing, but it's a 15 Viper part # and will fit the tuner III 's, I just bolted a set up last week.Are u in the states ? My dealer can't get that part # ??
- 40K
