Bluebullet
- Mar 19, 2005
- Massena NY
- Maine
I put an ECP kit on this year and want a good clutch set up to utilize the intake upgrade. My sled is a shorty with ECP kit 125" ripsaw and 168 pics.
What do you think?
Blue
What do you think?
Blue
- Sauk Prairie, WI
- www.ty4stroke.com
Heavy Hitters with stock primary spring. 52/44 helix with Yamaha White secondary spring.
HH Setup
3/4 allen in heel
3/8 Steel bolt in tip with 2 washers
7/16 Steel bolt with no washers in middle hole
HH Setup
3/4 allen in heel
- Sauk Prairie, WI
- www.ty4stroke.com
Oops, set secondary at 60
RobX-1
- Coldwater, OH
Matt,
Back when you had the Speedshop, I purchased the Supertunner Stage II kit that came with HH setup and 52/44 helix you mention to go along with the ECP filter kit I had on my 03 RX-1. I've been more than satisfied with the setup but now find myself needing to replace the helix. Most of the places I've searched offer the 52-44 as a custom job with the exception of Dalton Industries but Mountain Performance had it listed as an available helix and was cheaper than Dalton. However, when contacted, they only had a 53-43. My question is should I stick with the 52-44 or would the difference between it and the 53-43 be minimal? I've since extended the Expert X to 136" and re-geared to 23 top and 40 bottom. Any insight you could provide would be greatly appreciated.
Thanks,
Rob.
Thanks,
Rob.
