givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
Posted: Tue Jan 19, 2010 2:53 am Post subject: 03 RX1 Speedo Problem
I went out Sat. and my speedo started cycling all over the place. It wasn't reading anywhere near the speeds I was going and was jumping all over even when sitting still. Now it just reads zero mph. Anybody have this problem before?
RobX-1
- Coldwater, OH
More than likely, your drive shaft bearing (below secondary) is shot and may have taken out speedo sensor as well.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
RobX-1 said:More than likely, your drive shaft bearing (below secondary) is shot and may have taken out speedo sensor as well.
Thats what I'm thinking
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
The bearing is good and the sensor hasn't been gouged up . I think it is an electrical problem but don't know how to test for it. Ken...
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
Check to see if the connector at the back of your cluster is plugged in. Had the same thing happen to me. Turned out the connector wiggled loose.
Len Todd
I assume you checked the Speedo Sensor's wiring connections when you checked the sensor. Given this assumption, ...
Check the connector on the gage, then the main relay and if you have power to the gage from the main relay, but not speedo reading, then it could be the gage.
mooserackjim
- Feb 6, 2010
I had this problem on my warrior.Len Todd said:I assume you checked the Speedo Sensor's wiring connections when you checked the sensor. Given this assumption, ...
Turned out the wiring sleeve vibrated and wore a hole through the harness and grounded out on the frame.Its where the wiring harness is held down by the bearing on the frame near the toe hold.Pulled it out,wrapped it up and its fine.FYI
standard
- Jun 12, 2008
- Suamico, Wisconsin
- 2009 Nitro XTX
Bad cable
Check the wiring harness in the nose of the sled...in front of the battery.
That is where my problem was.
