04 warrior left spindle and housing
Todd Boeske
Grand Rapids, MI
I hit the side of a culvert this weekend and it appears I bent the left spindle and or housing? How do you know which one it is? The steering is almost impossible to move, I tried to remove the spindle and I had to beat it out of the housing so something is bent. Do I replace both or what? Anyone have these parts for sale? Thanks!
will it turn w/o spindle? if it does, then i think you found your answer. several very good sellers of used parts on here. it would be a good time to change bushings.
this happened to me, right side. I used a straight edge scale and compared to the good side. Mine was the housing, bought one on here. Put a short level or straight edge on outside of housing and measure the gap on the outside of housing and the straight edge and compare to the other side.
