05 rage clutch set up
uofm
Tawas City, Mi
Need a good clutch set up for a 05 rage. Was told to put in 14.5mm rollers. What else will i need for a good trail set up with a few drag races in between? Anything will help. I also have a set of heel clickers that i cannot seem to make work on this sled. Anybody have a good set up for the heelclickers?
use the rx1 set-up on the heel clickers. they should work just fine. On the secondary use any helix or angles under 43 degrees. A team with a straight 34 or 36 degree works well. woodtic
