HeatMizer
- Aug 18, 2005
I want to add a 2" handlebar riser, do I need the pivot adapter too?
I know the pivot adapter will add another 1-1/2" to the overall height...
Note: please disreguard Apex RTX's comments, he is a co-worker (sits
across the cubicle from me). I'm sure he will respond with some smart-@ss comment , all in fun mind you.
Thanks in advance for your help.
p0wd3rp1l0t
if u go with that u will need to change ur throttle cable and maybe ur brake line...not really sure on the brake line-but throttle cable is like $20
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
The Sportech ABR is perfect for what your trying to do. You should be able to get away with a 2 " total rise, Anything beyond that, you will most likely need longer cables...BBY
4Fighter
You're probably asking if you need the 2" riser in addition to the pivot to get the 2" overall, No?
I have a 2" powermad, solid riser on my RX-1 without any need for longer cables worked out so, so. I'm going to go 4" - 6" articulating, or relocate my steering column??? this season. The prospect of being able to stretch-out my long arms, and stand-up - intrigues me.
