05 RX-1 Transfer Rod is Bent
mdkuni
Houghton Lake, MI
I ended up taking my sled back to the dealer to re-sync the RA cable as I was only getting about 9 clicks of adjustment. They found dirt/grime that was preventing it from being adjusted......
They also looked over the sled and found that my transfer rod is bent! The nut came loose and now the rod needs to be replaced. Luckily there was no major damage to my track. Has anyone had this happen on there monoshock?
loose once
i was riding in canada on some nice groomed trails,of course i was bragging a little because i was the only one with the rx1. the day started and i thought everything was great,then as the day went on the machine was all over the trail,i thought it was the conditions but when we stopped for lunch i looked under and found the rod had come loose(very loose) i mean the machine was doing wheelies real easy. tightened her up and was back to normal
