RippinV
I have ~500 miles on the sled. The manual says RPM at idel should be 1350 +/- 100. My sled idles at 1000, if I turn the adjuster screw ( in the center above the carbs) up to increase the idle it revs really high if I just barely touch the gas. Is this normal?
Thanks for helping a 4 stroke newbie!
BigDog05
I had the same problem. I thought it was turbo related. I synchronized the carbs and it seemed to solve the problem. Have not had any snow yet to ride it though. Have not started it since I did the carbs. Carbs were way out though.
