06 Apex GT Set Up
yamadooski
columbus, oh
I can't seem to find it thru search so I'll ask for advice. I've got an 06 GT which I'm putting Pilot 5.7's this weekend and wondered how I should set up the suspension. I've not been happy with the ski lift in particular and would appreciate any suggestions. I'm 230 without gear and don't seem to have bottom out problems just handling in the corners. I've got my RTX set up great but since they have different suspensions any input will be appreciated.
I got rid of my inside ski list by lowering the front suspension and adjusting the transfer rod. Raise front end off ground. loosen the front spring preload until the spring rattles, then tighten one turn. Lower sled. Front a-arm should be close to level with the ground. I went 2 clicks up on the compression clicker from standard. Then adjusted my transfer rod to half way between standard and min.
This set up should rail around corners for you
some have went to a stiffer sway bar to keep both
ski's planted around the corner ! 13 MM in place of
standard 11 MM.
