06 Attak just dies !
**sj** said:
Im sure you know this...but if you overpack the bearing or put a non low temp grease...but im sure thats not totally it..also...make sure your parking brake isnt rubbing (set wrong)
you did change?check the bearings inside the chaincase right?
I use low temp grease to grease the skid but ---
I've used regular axle grease when I clean and repack both bearings each year for 18,000+ miles, never had a problem. I'm on my 3rd drive shaft bearing (changed due to water/snow easier to get into that one) but the jackshaft bearing is original.
I think what he is experiencing with the track stopping is pretty normal. Compare what it does with another sled -same year and model if you can.
