07 ATTACK CLUTCHING
power valve
can somebody tell me what is the stock clutching in an 07 attack. what are the weights, the pins that are in them, primary spring pressures, secondary spring pressure.
thanks
Good source of info. is the Yammie Service Supplement manual, you can order from the Yamaha site. Not sure if your '07 Attak's different than my '06 but:
Primary:
Spring 90501-582L1, color Y-S-Y, spring rate = 140#/in.
Weight 8FP-17605-00
Weight rivet Steel 17.2 for outter, center & inner
Secondary:
90508-60007, color W
Cam angle 51 - 43 deg.
is there a start pressure and a finish pressure on the primary spring. same with the secondary spring
You're welcome & get yourself one of those service supplement manuals, it's the Bible for us techno-geeks & it's cool to learn the ins / outs of the sleds!
