07 Attak Engine light flashing
Cornalpm
Fox Creek, Alberta
I have an 07 attak and i just finished putting it together after having to replace the A arms on one side, once i finaly put it together i went to fuel it up since the fuel light was on. once i drove it down to the gas station and fueled it up i got a check engine light flashing. its not flashing a code from what i can tell, its just constintly flashing. does anybody know what it could mean?
The light flashes and you have to look at the icons to find out which issue you have. If it's a yellow light, it's a warning. If it's a red light shut er down. Use the diagnostics to find out what exactly is wrong and then you know what to fix.
X2 The check engine light will flash if the air box temp plug is not connected, could be loose.
well after looking at it for the 4th or 5th time i found the problem, there was 1 sensor that was hidden under the cluster of wires that i forgot to plug back together....well at least i fixed the problem and its running great now.
