Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
My '07 had the fan update and when I checked my yellow grounding block I found a melted connector. I did the update myself, I couldn't be bothered bring it to the dealer for the cost of the wiring update.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
I would seriously recommend a new track. I don't know how people ride these sleds with the stock track. Cant get full potential out of the motor when the stock track doesn't hook up and a taller lug track helps eliminate the heat exchanger icing issue with certain snow conditions. The Phazer is the easiest sled I seen to change a track on. G.B.
