ctoshack
I've looked but to no avail have found any info on how to change the chain case oil. I did the regular oil and filter no problem but how do you do the chain case as I don't see a drain plug.
gcr3903
- Jan 31, 2007
- Phillips, WI. - U.S.A. -
- 2004 RX-1
You have to look on the bottom (obviously) towards the inside. Feel around or use a mirror. That's the way my 05 is.
apltx08
Yep its inside the tunnel, if I remember right its a #10 wrench, 250ml to refil...
gcr3903
- Jan 31, 2007
- 2004 RX-1
ctoshack:: What type of oil are you going to be using? I personally have become a firm believer in the use of Amsoil products.
ctoshack
gcr3903 said:ctoshack:: What type of oil are you going to be using? I personally have become a firm believer in the use of Amsoil products.
I bought the yamaha stuff right from the dealer I've never seen Amsoil products here in Canada then again I have never been looking either.
I use Amsoil in my chaincase, the nut is on the inside of the tunnel, just empty and refill..
- 18K
