kbrandt
Just a quick question to find out if anyone has played with the stock settings on this machine or not. When I first bought the sled I felt it had more pull and better top end than I have now since I played with spring settings. I bought it used so the previous owner may have gone away from stock settings. I changed my spring positions and marked the old ones with a felt marker...just in case. If I was not so anal about keeping everything clean, I would more than likely not wiped off the marks when I cleaned them up. Any help would be appreciated. Not shying away from a clutch kit if someone knows of one that is worth the money. I have added a fuel commander.
What do you want it to do. Ulmers kit will greatly help low and midrange, but hurts top end 2-4 mph
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
The secondary is set at 3-3 =60 I run mine at 6-1= 70% hope this helps
kbrandt
darv said:The secondary is set at 3-3 =60 I run mine at 6-1= 70% hope this helps
Thanks darv, that gives me a starting point!
