ExtremeRacing185
- Feb 22, 2011
I have an 08 Nytro RTX with approx 4500 miles. Last time out it was making a clicking noise right after the clutch engaged and i began to move. My belt looks fine however it is original. I m not sure if its a chaincase issue or whats going on. Anyone have an idea where to check or what might be wrong???
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
replace the belt and check again. thats a lot of miles on a belt. mine had 3000 on it when i replaced it as a precaution. Measured it and it was junk according to the manual
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
You might want to check your slider wear.ExtremeRacing185 said:I have an 08 Nytro RTX with approx 4500 miles. Last time out it was making a clicking noise right after the clutch engaged and i began to move. My belt looks fine however it is original. I m not sure if its a chaincase issue or whats going on. Anyone have an idea where to check or what might be wrong???
09nytro
could be ice in tunnel , let us now what u find
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Perhaps if you are studded you may have a stud ripped out of the track coming in contact with a heat exchanger? I have seen this scenario before...
dntmndr
ck the bearing on the drive shaft, left side of machine behind the speed sensor for the speedo....
