09 Nytro RTX
97sx700
Cottage Grove WI
So I pulled the trigger on the 09 Nytro RTX. Orderd the Ulmer Stage 1 clutch, and 144 1.325 studs. It has the dual carbides. Has there been any problems with this sled Mechanicaly or electricaly that i need to address before the season starts? What other mods should i consider looking into? Need ideas thanks.
Do a little searching around on here, there are a bunch of similar posts like this one. Also look in the sticky section too, will get you pointed in the right direction ;)!
