BA
- Jan 11, 2005
Does anyone have a method of finding a Yamaha PN for a M10 x 1.25 mm thread x 25 mm long suspension bolt? (fully threaded)
I'm going to fab up a new shaft for the limiter straps to attach to on the skid and the new design will require a much shorter bolt.
My goal is to lift the bottom end of limiter straps further away from the spinning track nubs (which have wore through 50% of each strap on my RS Venture...)
Thanks guys.
Thanks guys.
pistons
Many hardware stores have metric selections. The all theared part may be a problem.A 25 mm long bolt may be theared all the way already?
BA
- Jan 11, 2005
I'm getting greedy - hoping to match the green plating and flange hex style so it matches everything else...
It's pretty easy to find zinc coated steel bolts, but stainless or any durable plating with fine thread gets a little harder.
