BigJonny
Here's a silly question.. I just installed the 12 volt outlet on my sled.. I am gathering the sled needs to be running in order for it to work right?
Thanx..
Thanx..
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Correct.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
BigJonny said:Here's a silly question.. I just installed the 12 volt outlet on my sled.. I am gathering the sled needs to be running in order for it to work right?
Thanx..![]()
All depends on how you hooked it up?
Groomerdriver
Irv said:BigJonny said:Here's a silly question.. I just installed the 12 volt outlet on my sled.. I am gathering the sled needs to be running in order for it to work right?
Thanx..![]()
X2
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Whoops, that is correct...I thought you meant the stock outlet.
BigJonny
Yes, I hooked it up to the factory plug in on the wire harness.. Is there a better way?
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
Nope!
mtkaboater
If you want to keep your accessory on when you are on the side of the trail such as if you were using a GPS, you will want to wire it to the battery with an inline fuse.
Also wiring it to the factory plug-in, limits you to 3 amp fuse (if using the stock fuse). I blew this fuse a bunch of times running my heated shield not because the shield was defective, but if you get a little snow on your plug and then connect it, it pops the fuse.... pissed me off
