roller
I just picked up a 136x1.75x 16" wide track at hay days. It looks like there is some thing I need to do to get it to fit. I am looking for some input from someone who has done this install. Thanks
Turbo Tim
Make sure the chaincase bolts don't extend into the tunnel or they'll rub, ck for clearance at the rear brackets ,may have to replace some of the tunnel rivets , use the aircraft type that flatten inside the tunnel.Not sure if you'll need smaller drivers , like on the mountain ? ......I know 1.5 will clear but not sure about 1.75
16
You will need aftermarket drop brckets for the clearance.
roller
thank for the info. I plan on removing the heat exchanger protectors. I did this on my Viper with no problems. Is there anyone making the drop bracket? If not I can make it myself. This is my first 4 stroke and my first post on TY. I am a long time reader, This is a great sight!!
LazyBastard
MPI will have drop brackets, otherwise, get yourself a piece of 3/8" thick aluminum plate, cut out new drop brackets, and add spacers to make up the difference in thickness.
