The update kit is a 35-39 reverse angle helix and different color secondary spring. Also included is the aluminum rivet for the weight which replaces the steel outer. Total weight comes in about 69 grams.I'm not sure what else was included in the update aside from the helix , it was $99.95 i believe , made it noticebly snappier .
And then I had the 240 sm flash with Daltons , and BOV installed , along with relocating the transfer bar back, and it really changed the way it handled .
The flash and other stuff was done by Tim at Prostreet in Huntsville .
I plan to go back to him for the SS update, and have him set the weights to get the rpms to 8900 +/- .
He also redid my shocks .
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
The secondary spring supplied in the kit is the Yamaha black/pink, used stock on various Apex, Nytro and Vectors for eons.The update kit is a 35-39 reverse angle helix and different color secondary spring. Also included is the aluminum rivet for the weight which replaces the steel outer. Total weight comes in about 69 grams.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Thanks for info fellas!The update kit is a 35-39 reverse angle helix and different color secondary spring. Also included is the aluminum rivet for the weight which replaces the steel outer. Total weight comes in about 69 grams.
That's right, and I also should have noted that the helix has a machined ramp surface compared to the old version which was just cast.The secondary spring supplied in the kit is the Yamaha black/pink, used stock on various Apex, Nytro and Vectors for eons.
TurboAddict
- Jan 8, 2018
- Georgetown ON
- Sidewinder X-TX SE
So is the consensus that the update is worth it? My dealer had non in-stock but said we can order it in if I want it.... Just want this to be reliable belt wise...
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I believe the update is for 2017 's , not sure about 2018's .So is the consensus that the update is worth it? My dealer had non in-stock but said we can order it in if I want it.... Just want this to be reliable belt wise...
The new parts are now stock , I believe.
17 and 18's.I believe the update is for 2017 's , not sure about 2018's .
