fraser.911
- Oct 3, 2008
how long would a 2.5 pound bottle last if your going to run a 35-40 hp jet??? and in your opinon what is the best kit to run??? i'm looking for somthing that is the simplest install wise, and i would only be using the nitrous for raceing in feilds. and how do u have ur nitrous triggered?? by a botton or does it spray when the throttle is to the handle bar???
fraser.911 said:how long would a 2.5 pound bottle last if your going to run a 35-40 hp jet??? Appx 60 seconds
and in your opinon what is the best kit to run??? Lots of guys very happy with the Holtzman kit
i'm looking for somthing that is the simplest install wise, and i would only be using the nitrous for raceing in feilds. and how do u have ur nitrous triggered?? The slickest was is to put your button on the bottom side of the brake side of your habdle bars, so you can use your thumb to push it.
by a botton or does it spray when the throttle is to the handle bar??? Again, I would rather have a button so you can push when you need it.
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Fraser you can activate your nitrous in 3 ways....via the supplied button, via a ZEX wide open throttle switch, or now via the powercommander with use of the hub(I know what wires you need to tap into on the hub to activate the nitrous).
I originally used the ZEX switch because the Powercommander was not available that season.
