fishin4ladyz
Like the title says, is a srx700 suspension going to bolt right up in my 03 rx1 121. Have some broken parts in my skid when I took it a part. Found a decent price on the srx skid, thinking this might be a better way to go instead of trying to find all of the parts I need to get mine running.
grader
i think its a bolt in skid but you are going from bad to worse, as in pro action to no action, the srx is 8 inches travel, and will be down to 2 inches when you let the rx down on it.
fishin4ladyz
they look about the same, whats the difference between them?
snowdawg
Yes it will fit right in.
fishin4ladyz
Is there a difference between the skids?
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
Yes it will fit in, but one of the cross shafts is shorter. I did the reverse around ten years ago. I put an RX1 skid in my SRX. From what I remember, I pulled the shaft from the SRX front suspension arm and placed it in the RX front arm. Then it was bolt right in.
So, compare the two shafts and you will see the difference.
blkhwkbob
Yes. Less travel. You will hate it.fishin4ladyz said:Is there a difference between the skids?
