BigJonny
Hi..
Looking at a 04 RX1 Warrior. How are these sleds? The milage is low, and the price seems right. How is the suspension, handling, and motor. I do alot of trail riding, and this will be my first 4-stroke.
Thanx... BigJonny
Thanx... BigJonny
How many miles does it have on it and what are they asking for it. The 04 Warrior is a good machine and if you set the suspension up correctly it will give you a good ride. The only things that I would change personally are: install a set of Curve XS skis and depending on your riding style I would consider a different setup for clutching.
i love my 05 witch is almost identical to the 04.
set up right with ulmers/good clutching it is awsome in the trails.
love my curve skis as well.
welterracer
I owned a 04 rx-warrior, my brother now owns it..
Great running sled, good handling (but you must add a 13mm swaybar) and it rides pretty darn good..
It also helps to upgrade to a different set of skis (anything other than stock)
Hello BigJonny, I to love my 04 Warrior but if your user name applies to you being a big guy the first thing you will notice is the pro action skid is WAY to soft as it is setup for a 170lb rider. You can get a big boy spring but i have not tried it my self so i am not sure how well it works, I am looking for a good deal on an expert x skid. The other thing to note is the factory skies are crap, but with a good set of aftermarket skies it handles way better .
So good luck with the purchase and you will never go back to two stroke again !
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
BigJonny said:Hi..
Thanx... BigJonny![]()
ADD THE WIDE FRONT END KIT AND YOU WILL NOTICE A BIG DIFFERENCE IN THE TRAILS AS FAR AS HANDLEING GOES
04rxw10
- Jan 28, 2008
- Lisbon Falls Maine
- androscogginubm.org
Love my 04 Warrior just doing some changes to fit my riding style and conditions
low slung
- Feb 16, 2005
Outside of the oil-burning issue I,m happy with this sled and plan to keep it for a few more winters if it treats me well(got to check the exhaust donuts next month,cross my fingers).
04rxw10
- Jan 28, 2008
low slung said:Outside of the oil-burning issue I,m happy with this sled and plan to keep it for a few more winters if it treats me well(got to check the exhaust donuts next month,cross my fingers).
Mine dosen't burn a drop of oil
welterracer
My brothers doesnt burn a drop either.. over 6000 miles on it. too.
