2005 rx warrior upgrades
SCOTT HARMS
2005 RX WARRIOR
Last year I bought a 2005 RX warrior with 900 miles on it. sled is like new.
I want to do the upgrades that you all talk about. I have purchased the taller seat, I will be trimming the gas tank. and installing that.
I am asking about which suspension I should be looking for? The sled has the stock skid . I have read that some have used newer skids and someone has modified mounting plates.
So I am looking for a skid, the bigger front sway bar, 6 inch handlebar riser, longer cables.
Anyone have these items? or just point me in a good direction. Thanks, Scott 320 224 6197
Wow great find.
I left you a
message
The front Bar on it will be a 11mm, better then the 10mm that came on the earlier ones. I went to a 12mm and changed the front spring on ski's to a 2.3 straight rate spring from a 2.1 straight rate. Barn of parts might have an Attack mono that I think might bolt right in. Mountain sled cables are longer and what is used.
