wkeggenhoff
- Dec 20, 2007
- Ajax,Onatrio, Canada
- 2006 Yamaha Apex RTX
Did a search for info but search engine didnt bring anything up
Fuel light came on at 150 kms. Ran it too 200 km and filled up.
Took 35.7 litres
Had tobe getting really low because under hard acceleration and then decel it would stumble
thought these fuel tnks were 42 litres ? Is it still leaving 7 in the tank ?
Took 35.7 litres
black knight
i have ran out of gas before and it was around 220km -230km
I have run it with the fuel light on more than i care to count.
Always 9-10 liters left in tank when light comes on and i usually have the light come on around 170-180km
Depending on a few factors.
They are 38 liter tanks.
Murse
- Sep 7, 2012
- Cornwall, Ontario, Canada
- 2011 Yamaha Apex Std Red
light comes on at 160-180 depends on snow conditions and I have been to 195 with 8 liters left was told I can do 200km
cat hunter
You were running on fumes!!! I have the same sled and have run out a few times and the most the tank would hold was 35 litres .It's supposed to hold 38 , if you remove the plastic insert in the neck of the tank you can get more fuel in it but will some times run out on the ground.I have made an extra 5 miles to gas station after it quit by feathering the throttle!!!wkeggenhoff said:Did a search for info but search engine didnt bring anything up
Took 35.7 litres
