2006 Attak Rear Heat Exchanger
PEI Canada
Canada
2006 Attak
Hey Guys,
Its maintenance / upgrade time for the Attak. Installed a set of plugs, changed the oil and chain case oil and a set of donut gaskets today. I enjoyed the gaskets the least!!! lol
I also have a new rear heat exchanger to install, has anyone changed out the original tube for the rear exchanger that tucks up in the rear of the extended tunnel section? Is it as simple as removing the original and installing the exchanger? It appears I will have to drop the tunnel protectors to get the old one out and new one in at a minimum?
Thanks,
