RichsApex3573
- Dec 17, 2014
- 2006 Yamaha Apex Attak
Just bought the sled a few weeks ago and was running fine when I purchased it. Stored it in my garage for past 2 weeks tried to start it today and it wont fire up. Motor turns over fine and I hear the fuel pump work but it wont fire up. No error codes. Any ideas where to start?
hotrod
- Nov 16, 2008
- Maine
- 2007 Apex GT
did you check the gas. check air box for a nest. you need air and gas to run.
ZapeX2
And spark.... Check the easy, simple things first....
yama_rider
- Sep 15, 2014
- New Brunswick
- 2009 RS Venture
Is the fuel pump cycling on when you turn on the key? The Apex is known for fuel pump relays.
If battery is low, it will crank but not fire> give it a boost and see if it will run.
RichsApex3573
- Dec 17, 2014
Thx Tomany it was just the battery! Hooked up a battery tender to keep charged from now on.
