alaskan77
I just spent an hour searching for a post I saw somewhere on here, regarding my problem but can't find it now. I have a 2007 Apex Mountain that runs fine when brought out of the garage. Left out side over night it won't crank. Tach sweeps, pump cycles but no crank. I hear a clicking near the battery jumper tabs. Swapped out relays near your left foot stirrup with no success. I thought I read someone else having the same problem and someone posted pictures of which relay to check near the jumper terminal area. Starts fine when hit with a hair dryer or brought inside. Only problem is at the cabin I don't have the same luxury...
cacsrx1
Starter relay down by the battery. They turn green and loose connection. Replaced mine when I changed oil....around $45.
quebecmoutainrider
sure sounds like the starter relay..
