yamahahaapex
Anyone have a brake light that works but when the handle is pressed the light does not become brighter to warn others? Any idea where I should be looking to fix this problem.
REXX
- Jan 5, 2007
bulb? should have two elements...maybe brake light element is burnt. change bulb.
If not this, is your wiring to brake lever okay? maybe disconnected, tore off or broken.
REXX
WSTRN Canada
REXX
WSTRN Canada
yamahahaapex
Is the back tail light not L.E.D?
REXX
- Jan 5, 2007
Sorry, was thinking back to the RX-1. I took the rear rack off, right off the bat.
I would check your wiring then.
REXX
Western Canada
REXX
Western Canada
MT RX1 Mountain Man
I think the sending unit is right underneath the brake lever, you might check that also....
yamahahaapex
I was thinking of that too. I am going to see if maybe there is ice blocking the lever from depressing all the way or just in need of some lube.
ski-bum
Brake switch on the underside of your brake lever.
yamahahaapex
it was the sending unit. works fine now. thanks!
