2007 MTX Rear Suspension
prowler1
I bought a 2007 MTX for my 13 year old boy. Problem is, that when the sled sits normally (with no rider on it) the rear springs are bottomed out on the teflon blocks. I read that you should have 10 to 15 mm of space between this teflon block and the arm (when rider is on the sled)? The cams are rotated all the way to the "H" position. Is there another way to adjust this? Or is there a way to fix this?
