2007 RXT suspension adjustment Clicker shock
giddy up go
Lindsay, Ontario
Canada
2011 apex er
1) I was wondering can someone tell me about the clicker shock adjustment . I know it it's too soft you get a pogo effect, as you turn it in your ride starts to improve . What could happen if you need to ride with it near competely tightened down. At one click from bottoming the clicker out is the best ride I seem to get. Can I do damage to the susp. or shock adjusted this way? The ride is acceptable here at that adjustment.
2) I know I am up to near the limit of these shocks saying that should I want to improve the ride anymore would I be best to put in heavier springs on the shocks or revalve the shocks
I am not usual a real agressive rider just the trails can get some back busting bumps in them at times just like keeping from being bounced around. I am about 225 suited up with gear on.
Any comments would be appreciated
Read the post in this forum ( shock valving 101 07' apex rtx vs, revxp) you will get alot of info here.
Thanks Chadman execellent reading and lots of insight there. Lots of reading. Thanks for your help :4STroke:
